gauge electircal hookup
avaien
242
24
Nov 30, 2003
Cincinnati, Ohio
I am hooking up the lights on my boost and egt gauges and saw that an easy place to tap in is the cigarette lighter light. Is it the stripped green or black wire coming from the light that I tap into? And can I just tap the power supply for the egt gauge right into the ecu? I saw on vfaq that pin 25 was a 12v power supply. heres what I found
IMO it would be a PIA to wire the gauges all the way to the lighter. I just took the cover off the stock gauges and spliced into wires from the dimmer switch. That way I had them run under the dash and you cant see the wires at all. It was super easy and the wires and really short.
Michael
:laser: :talon:
