Gauge cluster (rpm and speedometer)
ballin_boi13
Oct 13, 2006
las vegas, Nevada
its weird couple days ago everything was working fine then yesterday i turn it on and the whole gauge cluster doesnt work except the highbeam light and turn signals...no sound when door is open radio doesnt turn on...next day gauge cluster doesnt work again but the speedometer works now and half of the cluster illuminates...need help
Try removing the cluster and clean the sockets, maybe something its not making contact, it has happened to me when installed my reverse gauges and took the cluster off.
well i go today and turn the car on and the only thing that works on the gauge cluster are the turn signal lights and i took it out and put it back in and nothing!! help
Borrow a cluster and try, If you removed it and worked by cleaning the sockets, maybe the cluster its about to die :D
ive also been having cluster problems.... my dash cluster will not work at all... no turn signals no tach or speed... i replaced it with a new one and nothing... all fuses and relays are good.... unless im skipping a hidden one... but i checked all the driver fuses and hood relays
