gauge cluster lights wont work
boostjunkie304
Nov 7, 2008
triaelphia, West Virginia
so my 2g gauge cluster lights wont work i have now ideas how fast im going at night. and my cig lighter and ashtry lights wont work so which is causeing my egt boost gagues not to work if check all the fuses and i cant figure it out HELP
sounds like a fuse. Get a meter and check them. Sometimes a screw or something metal will get into the cig lighter and blow the fuse as soon as you put it in.
theres nothing in the cig lighter. i check the fuses everwhere. the bulbs are fine. but maybe i should check the dimmer switch
Its most likely going to be your dimmer switch.
My dimmer switch went bad about 2 years back and caused all of my interior lights to not work.
You'll have to ground a certain wire on your dimmer switch harness, I'm not sure which one but I could check for you possibly when I get home tonight.
But definetally test your dimmer switch before you try grounding this wire, If this isn't the issue it could cause more problems.
If you have a haynes manual you should be able to trace down the wire and wire colors in the wiring diagrams in the back of the book.
ok guys i replaced my switch checked all my fuses and still nothing. but when i was under the dash i found this white panel it had three 12v relays and there was a fourth spot and nothing in there. also my knobs for the heater a/c isnt working
