Gas Smell in car.
Boostinsideways
Banned Member
1,641
16
Feb 4, 2011
Arab, Alabama
Doesn't go away overnight, dealership won't do the recall sooooo it looks like I will be replacing the fuel sender seal.
I already ordered a re-wire kit and an o-ring. Anything else I should check? No visible leaks, new injector seals, no exhaust leaks. Wideband is reading nominal... So I doubt a I am running any richer than I should be at cruise, and I am starting to tap out the fuel pump at WOT (Starts approaching stoic) so I will be re-wiring it at the same time I replace the seal.
I had a similar issue with gas smell, I tore the ring when installing my 190 somehow. Mitsubishi had to order it, being my dd I went to the junkyard and grabbed one off a 3g been good since.
I meant If it isn't the seal. I think it is more likely the seal, but was throwing some other options out there in case it wasn't.
Ah, I put an "If" in front of your post and it made sense then :coy:
It is another possibility but as you mentioned, it would need to be saturated and would take a lot to travel into the cabin through the vent system. Storage area would be smelling like fuel as well.
My 2g I had, did the same thing. Was really bad after filling the tank up, smelled so bad thought if I lit a smoke the car would blow up. Come to find out the sending unit seal had a nice rip in it. I replace the seal then no more gas smell
Yep, I get the gas smell worse when the tank is over half full, and its at it strongest when the car has been freshly filled.
I also don't have a charcoal canister/evap purge. The Previous Owner removed them before I purchased the vehicle and they were not included with the spare parts.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
