Gas smell in car...
Levesque
152
Apr 19, 2009
Chicoutimi, QC, Canada
hey guys in my car it really smells like gas sometimes.
Only smells like gas with the windows down.
Windows up it does not smell like gas.
I do have an exhaust leak at the flex would this cause the gas smell with windows down ?
Short answer : Yes
You're leaking exhaust gas from your flex pipe, which in turn, will allow you to smell all of that unburned exhaust.
The first step in solving you problem would be to fix the exhaust leak which most likely is the cause of the fumes. if it still continues to smell like gas check the fuel lines especially fittings such as on the fuel rail and fuel filter.
Beat me to it
XiKeiyaZI
Short answer : Yes
Beat me to it
XiKeiyaZI
Short answer : Yes
Still tagging your post as helpful.
And for OP :
Get that leak fixed and if you're still smelling it then you likely have an exhaust leak at your exhaust manifold Pre-02 sensor. This would cause, not only a Rich condition, but will kill performance and you WILL smell the fuel from this.
