420A Gas,air,fires,no start
Mrdjflores
35
Jul 10, 2016
Louisville, Kentucky
Engine starting puzzle
First let me say that i'm new to Eclipses and the 420A engine. I'm not new to cars and fuel injection. My project car is a 95 Eclipse RS, A/T (going to be my daughter's first car) Car started and ran okay when i got it, had bad rings and low compression. so continued on to do a complete engine rebuild. Now the engine is back in it's happy home, but have come across a starting problem. At first, the engine ran good, then mysteriously quit running (long story short, out of fuel...DOH...) Put gas in it and it fired it up hence the following: 1)Started, ran rough, found #4 injector leaking - replaced all injector O-rings 2)Started, ran rough, found Fuel line inlet leaking - replaced O-Ring 3)started, ran rough, started checking plugs and connectors - engine died 4)Now won't start.... Here is what I know: *getting a little over 40psi at the fuel rail when cranking. *fuel getting into cylinders (fouling out the plugs) *getting spark at coil packs and spark plugs (seems a little weak for a spark) *Tested CAS (only get 9v at harness, others tests okay) *Tested TPS - good *Tested IAC - good, but going to retest off engine *Tested MAP - good *Tested Engine Coolant Sensor - good (have to wait for better weather to test CPS and Knock Sensor) *Double checked timing belt and alignment - good *Replaced spark plugs again, and gap accordingly I have a replacement ECU on the way. I'm also beginning to suspect fuel pump again, maybe it can build up the pressure but not deliver the volume?? I vaguely remember hearing the fuel pump prime when you just turn the key on, but now i don't, but does build pressure when cranking. Any thoughts?? Anything I obviously missed?? thanks, Dan
