Garrett G Series Turbos on a DSM, Anyone?
Car Cannibal
691
168
Jun 7, 2003
Chicago, Illinois
These are killing it on other cars, curious if anyone has any input on this turbo in any regard from install to power etc??
V band, T4, Twin Scroll and spool?
I'm thinking G30-770 (58/55) would be an incredible street/strip turbo around 28-30psi street boost. My new 2.2L, 10:1, 274, twin scroll should be an easy 675hp at 30psi with that turbo.
Likely out of the budget of a typical DSMer once you factor the parts needed for the install. Would be nice to see an adaptive turbine housing available which allows them to bolt directly to a stock manifold and o2 housing, but part of the magic behind these units are the obscenely-large turbine housing a/r options. If you put a 48mm G25-550 into a DSM-flanged housing it's going to work like a $1500 16G.
Ya, $2400 for the turbo alone isn't the easiest to swallow considering most people wanna offer you $3000 for the car.
But they're showing a nice bump over the last generation turbos if you can afford it.
Bump
Anyone run one of these yet, details?
