garrett 50 trim install components
paintball4fun21
168
Jun 13, 2006
onalaska, Wisconsin
i just bought a garrett 50 trim to4E, manifold, and a 38mm tial wastegate.......Im wondering where I can get all the other necessary components to install this as I am upgrading from the 14b
thanks!
I agree.
You will need bigger injectors,a bigger fuel pump(walbro 255)something to tune with,boost gauge,a/f ratio gauge,boost controller, a wide band would be nice and theres more you could use.
I would hold off putting that 50 trim on till you get some more upgrades to support it or you wont see any gains might actually be worse than the 14b.
sorry I think I miss-worded the question.........I already have the fuel mods and dsmlink, just not installed yet..........I was just wondering what I will need for installing the 50trim and where to get it(gaskets, new water pipe? or new oil feed line?...things like that) I was just saying i already have the new manifold and wastegate.........I just wanna know what components I will need to install the turbo only.........thanks!!
alright cool...........where should I get this stuff? any good sites out there for cheap? also I was mistaken.... its a to4b not e..........does this mean that it will bolt up to the stock mitsubishi manifold and o2?
thanks!
is there anything else I will need to bolt this up? new oil lines or anything like that? and if so where is a good site to get them from
thanks again:talon:
I'm in the middle of installing my sbr 50 trim. You will need an oil feed line from the oil filter location, an oil return line, you'll need a hammer to bang in your coolant line to make space. 7cm gasket and new 02 housing gasket would be nice. While its all out, go to town porting the manifold and 02 housing. I got all my stuff from extremepsi.com. Cheers
