DearestNameless
- 308
- 1
- Jan 16, 2010
Linton,
Indiana
Its a 1998 Eclipse GST Spyder
The pictures below isn't mine I'm just using it as a reference I will get real pictures as soon as I can
So first of there is a blocked off vacuum line around the throttle body/intake. It is the third one down and it is marked with a P. What does this do? Why would they block it off? And how do I fix it?
Secondly there is a pluggin attached to the trans that has been broken and the leads have been soldered together. Same questions as above.
Then there is a huge line disconnected from the rear of the engine. I'm guessing this is the AC line? What should I do?
Lastly there is another plug behind the timing gear cover that is attached to a metal bracket? Same questions as above.
If anyone could help it would be greatly appreciated.
http://img683.imageshack.us/i/95344420.png/
