New gameshow, It's called Name That Noise!!
wibblersnatch
512
Sep 14, 2002
Fleming, Ohio
I've had that sound before after my rebuild, it turned out to be the timing belt hydraulic tensioner. The tensioner arm vibrating against the tensioner due to bad tensioner. I used a stepthiscope (sp) and located the sound. It was really loud when I listened the top motor mount bracket on the block, at first I thought rod knock. Then I took all the belts of and the sound was still there, so I then took timing cover off and listened to the tensioner arm and it about blew my ear drum. I hope this is your problem.
Ok, well I took the cover off and still had the noise. The timing tensioner pulleys are new. I'll take off the belt and put a different tensioner on in a couple of days and post back. Thanks for the replies.
