Galant A/C Bearing replacement
cracovia
53
10
Jan 23, 2022
Buenos Aires, South America
Hello everyone, i have a galant 7g and I need to replace the ac pulley bearing, the part number is MB878243 and its no longer available... Did anyone replaced the bearing, and can tell me the bearing number specification please?
This is the tensioner pulley bracket.
Thanks!
Clean off the bearing you have. It will be stamped on the bearing. Little stuff like that is common and cheap.
Yes i know, i just want to replace it in the moment, because the closest "bearing shop" its 40 miles away...
Point taken. Problem is this isn't a Galant site. That bearing also isn't available from the dealer. They want you to buy the whole pulley. If you at least get a dimension on it the part numbers are dimension based. I'm gonna guess 62mm dia for starters. 6203rs bearing possibly. Common if I recall. I keep a couple common bearings in my toolbox because they're so cheap.
Well, i removed the tensioner... the problem is in the compressor, nice... thanks bro
