2G A/C Bearing
Largo-W
Oct 12, 2011
Kraków, Europe
Hi,
Anyone know what is the number of AC Bearings? I have a 99 GST and can't find this bearing number, if I take off AC I should replace bearing as fast as possible to avoid refuel of AC.
Any numbers will be helpful :hellyeah:
Best regards,
Largo
if you remove the compressor you will to recharger your system
Indeed, you're right :hellyeah:
But I should check my compressor, change the oil and others thing, because almost year I had a car I didn't interested about it.
So, mechanic should change bearing when he take off from car and compare to others available :)
My compressor take R12 gas or R134a?
