g63b: crank gear shim? oil pump issue?
Akauf587
Aug 17, 2005
New Holland, Pennsylvania
I've been searching and checked the factory service manual, vfaq, etc and cant find an answer to my problem.
issue/question 1:
I'm putting together my g63b for my mighty max p/u and I'm running into an issue with the balance shaft pulley. It is sitting too far back causing the belt to rub the font cover and poor alignment with the tensioner and b shaft gear.
Is there supposed to be a shim between the crank balance shaft gear (b) and the crank?
issue/question 2:
I picked up a used oil pump assembly that did not come with a drive gear. I try to swap mine onto it and the shaft is much smaller on the new one. I pull the pump apart to switch the pump shafts/sprockets and they are different.
My original one matches all the oem dohc oil pumps I have around.
Can I use a dohc oil pump assembly on the sohc motor? I know how they differ but is it an issue?
thanks is advance to anyone who can help,
Andrew
I'm talking about the balance shaft gear on the crank. It sits too far back. I have that spacer behind the balance shaft gear and with the belt lined up with the balance shaft crank gear the belt sits very far back on the balance shaft gear and tensioner pulley.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
