G4CS 6 bolt 2.4 Build, Cam Gear Options
ChessmoDSM
465
201
Apr 22, 2017
Burlington, Vermont
Does anybody have some real-world information on what Cam gears can be used used for this build, the block/crank is out of a 91 Hyundai Sonata I did find this blurb from the long thread about 4G64/G4CS builds but was wondering if anybody had experience with something else that worked?
Thread:
https://www.dsmtuners.com/threads/looking-for-4g64-g4cs-answers-look-here.100677/
Blurb:
I could be wrong but I believe there is no such thing as a dohc 95-99 galant that the cam gears will work on on this setup. The cam gears you will need are off of the 94 gs dohc galant. They only made it for 1 year. The head bolts directly on. The cam gears from a 4g63 will work but you have to make marks on both of them 1/2 tooth advanced. Use the new marks to set the engine at tdc..
I also found this on RTM Racing but it says its specially designed for a 95-96 CAS setup and I think it's moe for the 4G64 unless I am mistaken:
https://www.rtmracing.com/xcart/product.php?productid=20767
This is the intake cam gear required when mating a 4G64 2.4L bottom end with a 4G63 head. The gear is of special design for use with the 1995-96 CAS (MD300102).
NOTE: When running this cam gear on a 4G64 block and 4G63 head, you should also use a timing belt designed for this application (MD331076). For details, please refer to the "Related Products" section near the bottom of the page(I do believe this is the right timing belt though)..
Thanks for any and all advice!!
I’ve ran the 2.4 cam gears on a old 2.4 build and I currently have aem 4g63 cams gears on my 2.4 that have been degreed in. I have never remarked stock gears and ran that way though. You can run the 95-96 cam gear with any style cam sensor you choose but you can only use the 95-96 cam sensor with the 95-96 cam gear.
I was lucky enough to find the 1994 Galant GS Cam gears (in and out) along with the timing belt from a fellow DSM'er.. Stay tuned for the upcoming build..
Hey Cheesmo,
How'd that build turn out?
Im currently putting together a Delica L300 with a 4G64 SOHC. I've slapped on a Garrett GT2554R and have a lot of supporting mods. I need an adjustable cam gear because I just put in a custom ground cam that's basically an HKS 272 grind.
I Cannot find a source for the correct cam gear from a 94 GS Galant to save my life. Thinking about pulling the trigger on a 4g63 cam gear and adjusting it a half tooth, like you said.
Link here: https://www.ralcorz.com/product/per...rhsQ6IciGQPhM2QXCekNtzOXbjBKrwVoaAtzOEALw_wcB
Any thoughts on this or sources for the right stuff would be greatly appreciated. Cheers
