FWD turbo tranny in Hyundai
As long as it has the 4g63 I dont see where the problem would be in swapping the transmission from a FWD 1g into it. Just check to make sure the mounts bolt up to the trans the same way, and also check to make sure the axles and clutch splines are the same.
There is no tranny mount on the passenger side inner fender, you will have to bolt one on.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
