turbo fwd tranny in non turbo fwd
rhohan72
30
Mar 4, 2004
Orem, Utah
My buddy has a 91 laser rs turbo that is being parted out. I have a 93 gs dohc that i need a tranny for.
Question: Can i use the fwd turbo tranny in the fwd non trubo car?
I did not find any articles on this specifically. The non turbo to turbo conversion thread gives info on retaining the n/t tranny, but does not give info on turbo in n/t.
Thanks in advance.
Yes it is possible but you will need a turbo flywheel and clutch for a turbo tranny. And possibly the shifter cables not 100% sure about them. The gear ratios are different on a turbo tranny but other than that it will work.
Check the tech article section under the tranny heading. I did a complete writeup on the swap.
The NT Clutch and flywheel will work in the Turbo tranny just not vice versa.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
