FWD Autocross Springs With Konis
teklein
107
Feb 18, 2004
Simpsonville, South Carolina
Hey,
I was wondering what FWD guys are running as far as springs go.
Car will be autocrossed, with Konis.
Thanks!
teklein - It really all depends on what else you are going to using the car for. If you want something I believe would be a good street setup and for some descent track suspension, try going with something around 350 lbs in the front and 225 - 275 lbs. in the rear. Anything too much more than that in my opinion will give you a pretty rough ride around town on a daily driver. You could possibly go higher, but tis really a preference at that point on what you can take and put up with on the road every day.
Are you going to do something like adjustable Ground Control Coilover sleeves or just looking for springs? Allot of DSMers like the Koni + GC combination. Just something else to consider as well. Hope some of this helps. :thumb:
Wasnt planning on the GC sleeves.
I dont mind too much about the ride around town, ive had Neon ACR's with the full Koni/Hi-Rate treatment. But that was a proven combo on those cars.
Im basically for the best coil springs for a occasional autocrossed DD NT Eclipse.
