Full throtle.. slow response
yukiz
458
4
Jun 17, 2009
Bay area, California
ok......here's the problems........
last month,...... my car got backfired....
so i replaced the spark wires and the spark plugs........
first 2 days was okay.....
next day..... the car got really slow response while running.......
2nd gear pull from 2000 RPM with full throtle was really slow........
it is like climbing up to mountain with 3rd gear...
can anybody help me,.....??
thanks for response.,
That would be my guess.
Have someone press the pedal down all the way while you check under the hood to see if its 100%.
i will have to check tomorrow since my brother is not here today....
but thanks for all your inputs.....
btw... what is boost...
how do i do boost leak test......
thanks again:D
Ok.......
i dont get it.....(noob)
this car is my first DSM........
can someone show or send me a link to do boost test??
thanks
wait........ my car does not have TURBO......:D
thanks for the links tho......
Usually when there is a backfire, you're running rich. Add in the fact that you're experiencing a slow acceleration problem and you may have an issue with your O2 sensor or fuel system. Have you recently replaced or worked on anything fuel related, including the fuel filler cap, pump, FPR or injectors?
Slow acceleration is more a symptom of poor spark timing, but if you're running rich enough to be backfiring, then there's obviously at least a small fuel related issue.
You could be running rich
Dang it didnt see your post... :coy:
