fuel
eDeclpse92
351
4
Sep 6, 2008
Belleville, Illinois
hey, ive been looking around for a while and cannot find what I am searching for. I am looking for a fuel feed and return kit. not the filter to the rail. I need from the pump to the rail and back obviosly. i have heard someone sells these kits for about 200 bucks and i cant find them. (I cannot use the lines that are on the car, they are bad.) Can anyone help?!!!
Thanks, any help woiuld be appreciated.
http://www.streettunedmotorsports.com/dsm/dsm_fuel.htm
STM FUEL TANK TO RAIL KIT
The STM Fuel Tank to Rail Kit comes with everything you'll need to replace your old, rusty fuel lines and your stock, restrictive fuel filter from your factory sending unit/fuel tank to the rail. Our -6AN kit can be used with your stock sending unit, but if you need some serious fuel, our -8AN kit is designed for the aftermarket kits such as the Full Blown Kits (below). Click for more info.
Starting at $219
alright thanks a bunch man. i guess there would be a return kit too then?
I saw a do it yoursel section at the bottom, They have alot of nice stuff and their prices arent too bad. You can also run metal brake line since the return isnt under pressure. Alot of guys do it that way. You get a roll of 5/16 or whatever you want and run it from the tank to the reg.
