Fuel??????
alanstalan
May 20, 2005
Shady side, Maryland
How does a 2g fuel injector work?, i know it needs a pulse.
my problem is i need to kno where evrything thing is located and what it does because when i turn my ignition on the fuel pump kicks on and dosent stop and my injectors are wide open, (850 injectors and 255 fuel pump) use your imagination to see how ugly that got!,
so i need to try to fix this problem or would it be easyer to make my own rewire of the fuel system?
any details or diragrams and information would be greatly appreciated!
thanks
alan
+12V from the battery (via MFI relay) goes through a 6 ohm ballast resistor (on middle of firewall) and then to one side of the injector. The other side of the injector connects to the ECU which connects it to ground when firing (very short negative pulse - too short to measure w/o a scope). If they are all on you may have an ECU problem - check it for leaking capacitors and shorts.
  • For sale 1G DSM Interior Bits
    Selling some extra parts and pieces I've got left over and I don't need around. Prices are in...
    • Mike_Hunt
  • Wanted Interior trim clips
    Looking for these plastic pieces and clips.
    • Rohitter7878
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Price is shipped USPS flatrate. Been sitting in box. Someone...
  • Wanted WTB 20g TD06H
    I am looking to see if anyone has a 20g TD06H turbo or equivalent for stock bolt on. I...
    • RedGST98
