Fuel upgrades
jdm_hero
Jan 7, 2008
ft.worth, Texas
The 255 pump will be fine. However keep in mind if you get the 255 you'll need a fuel pressure regulator to go with it. The 650s might work depending on how much boost you're running with the 20g. If your running a lot of boost then you might need to go bigger. Yet again if you go bigger than 650s the you would have to get dsmlink. The safc can only compensate for up to 650cc injectors. Also depends on what you hp goals are for the car. I would just get dsmlink and get 750s or larger, probably larger seeings how dsmlink can control whatever you throw at it. It would suck to get a safc and 650s then find out you have to get larger injectors and link.
Sorry I forgot to mention i'm looking for about 350ish HP and I already have a b&m fuel pressure reg
Which 20g? td05h or td06?
If you'e going td05h, then are you getting a clip?
650 are fine for a tdo5h turbo with any compressor. But if you go dsmlink, it's a waste to get smaller thn say 1000cc injectors. They idle like stock with dsmlink.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
