Fuel Tank Leak at bottom
get a new tank...or drain it and let it dry and drop it to facilitate other repairs :)
i wouldnt recomend repairing it either man, be better off purchasing a new one or finding the actual source of the leak. from the video it didnt seem like that was the leak...it was running to that flat,low spot from somewhere else
My tank is leaking right now as well. I dont know if the 1G and 2G set up is the same or not but mine is coming from the gasket that seals between the fuel sending unit and the tank. From there it runs down to the bottom and drips just like your. But not half as bad.
Mine used to leak as well. I ended up having a huge tear in the rubber line that goes from the sending unit to the fuel line. I bought a SS sending unit to rail fuel line kit to fix my problem. I would suggest bringing your car to a shop and have them diagnose where the leak is coming from.
gosh i hope its just some kinda of gasket or hose..... ill take it to the shops next week when i off work
