TSIfreek
- 1,674
- 18
- Dec 14, 2003
cary,
Illinois
Hey guys I think I am having a problem of running rich and getting rich knock. When I had my motor out I removed all the emmisions except the pvc. I am still on the stock fuel system with a 1g unhacked mass and a rewired 255 HP pump with the stock regualtor and 450s . I can smell fuel out the exhaust my exhaust tip is black but I have no black smoke . The engine runs fine no missing or backfireing but spool up is a little slow. My plugs look like new as well. I am not running a cat but still think the smell is alittle exessive. I have a new 02 sensor I put in with the motor and acording to the logger its doing its job and have .90v on a WOT pull and cycles nomally at Idle. I have a small boost leak at the BOV but it doesnt start leaking untl about 13 psi but I am only at 10 psi now.
My EGT gauge is not working so I cant rely on that I just have the logger to look at.
I was thinking of a AFPR to see if that could be the problem knowing I am over running the stocker. Thanks for your replys
