NWHTanK
Freelancer
- 1,670
- 954
- Apr 23, 2011
Odessa,
Missouri
How difficult is it to make a fuel rail cant find one that suites my needs
Stock hybryd well the motor has some stuff on it that that up grades it abit. The reason im asking is that the engine that going in it has the inlet next to the cam gears and goes over the valve cover the line is plastic. Aftrermaket ones put the inlet. In the same area. I would like inlet on the back side of the head so as clean up the vavle cover area and to make a clearer shot to the fire wall with out plastic pluming.
How's this look?
Aluminum Fuel Rail Stock, price per foot : atpturbo.com
If you can use a DSM fuel rail, just get some -6AN adapter fittings for the rail and you can put the inlet/outlet on either side. I've seen some guys weld a -6AN fitting on the middle of the rail for the return line and have a feed line on both sides.
eclipse fuel rail fitting | eBay
