GVR-4 Fuel pump relay
david harker
30
Jun 11, 2014
Hagerstown, Maryland
Fuel pump not turning on, is this the relay ??
Whats the brown wire? Could be abs shielded wire but I doubt mitsu would stuff it through a cut grommet. Speaker wire? Anyways... What's the red big gauge wire, for battery? The picture you showed is just the connector. The relay would be in one of your main fuseboxes. Looks up posts on here on how to test the relay. The connector and wiring to & from it look fine.
Red wire is battery and not sure what the other Wires are , kinda a mess when I bought the car . Trying to sort it out . I have never owned a gvr4 only dsms.
