fuel pump question
boostin90gs
100
Nov 1, 2011
pasco, Washington
Is there anyway you can check if you have aftermarket fuel pump without pulling pump. I just bought 92 gsx and it has aftermarket fuel pressure regulator,didnt want to pull pump if there was a easier way.
The only way you can be absolutely sure is to pull it. You can also see if its re-wired as well and maybe any different fittings to see if its a kit, to give more insight.
