fuel pump question
gsx4357
103
Sep 26, 2010
maricopa, Arizona
hey i just got a new fuel pump from forced performance 225 pump. now i took the stock one out of the sender and tried to put the new one in but the output nipple of the pump that has the black o-ring that goes in the sender is smaller than the stock one and doesnt have a tight fit. how do i fix this?
you bought it for via a 2g setup up.. did you check any of the packaging to make sure it didnt come with any other rubber fittings to replace it.. did anything happen to stick in the old one?
If that pump is anything like the Walbro I just put in, there should be an install kit that was included or purchased seperately that will have the correct black rubber end piece for that pump as well as anything else that varies from OEM fitment.
