Fuel pump question
918_gsx
127
May 1, 2011
tulsa, Oklahoma
Can anyone tell me offhand if there's a fuel pump out of another vehicle that will fit in my car that's rated 190lph or higher? Same with fuel injectors.
An EVO 8 FP (Denso 195130-3360) flows just a tad bit less then a Walbro 190 (~ 160 LPH) and the Supra FP (Denso 195130-1020) flow a little more then a Walbro 255 (~ 260). There is also the 3000GT pump which I know flow around 190 LPH but I don't have any exact numbers for you. Check out this link for some comparison numbers: RRE Instructions and http://www.stealth316.com/2-fuelpumpguide.htm (this one is form a 3000gt website but still has a lot of good info and well as a lot of flow comparison charts)
As far a factory injectors the EVO 7-9 injectors flow the most which would be 560cc. Here is a list of other Mitsubishi injectors (which are color coded):
pink - 240cc - (1g 2.0Ln/t)
tan - 390cc - (1g turbo auto)
blue - 450cc - (1g turbo m/t, Galant VR4)
black - 450cc - (2g turbo)
yellow - 510cc - (evo 1-3)
pink - 560cc - (evo 7-9)
Hope this helps!
No, I didn't get a chance to look at it til now. Thanks though bro.
I just looked at the injectors. Blue. That good for up to 300hp? Mines an auto
You are welcome.
300 hp? I wouldn't count on it. 450 injectors are stock (for a 1g M/T, looks like your 390's have been upgraded) and they won't get you too far before you get high IDC's and start leaning out due to lack of fuel. The only way you are going to be able to tell your IDC's is with a logger. Check out this thread for more info: http://www.dsmtuners.com/forums/frequently-answered-dsm-questions/277747-fuel-injector-questions.html
Alright man, thanks for the info. Got a bigger issue now. Pretty sure my turbo is toast
About to start a new thread. Hoping its just the oil seals or something. still new to the whole turbo thing myself
