Fuel Pump Not Working!
the_anti_honda
152
Feb 27, 2003
Menifee, California
ok guys this is the deal.
i just put in my new walbro 255 and it dosnt work. i checked the lines and found that the plug going to it has NO power whatsoever. where could the cause of this be and what might the cause be.
i installed while the car was down pretty much my entire mod list. i have come to think that it could be the AFPR or the TT. the AFPR is hooked up fine but i dont know if it works because the pump is not pumping any fuel into anything. and the turbo timer is not all the way installed. the harness is in and it is grounded but the wire to the e-brak is not connected yet because i dont know what wire is what from the e-brake. could this be a problem?????? i hooked up my walbro 190 and had no problems soooo WTF happend? just all of a sudden fuel pump has no power?
ok update,
i hooked up my grey wire to my e-brake for my TT and it reads 12v when its up instead of down so thats all @$$ backwards and it wont switch to 0v up and 12v down. so something is screwed up there. also i can not get any power in any of the wires about half way up the car from the pump. should i take the pump out and check it for something? reinstall? i needed to start my car on the 19th it is my last day off before i am supposed to run my car at the track. PLEASE PLEASE help i have 1 day left to fix it for a while. :cry: :cry: :cry: :cry: :cry: :cry: :cry:
