fuel pump hissing and ALOT louder than normal!!why???
redgst95
98
Dec 6, 2004
Mobile, Alabama
i have a walbro 190, rewired if that helps my problem is that tonight i noticed that it was terribly terribly loud and it was hissing what would cause this and what do i need to do to fix? please fill me in thanx
Is your tank empty? Mine gets reallllly loud when I let it get real low. Other than that, I guess it could be the filter on the fuel pump itself. Change that every few months, and it won't make noise. ;)
RedRain said:
Yea most likely when u tend to run ur car on a low tank most of the time, you will hear that SOB scream! Give Me Gas! If you run it low all the time, ur pump will go out sooner.
well the only time it made that was last night and i had a full tank but i did but some injector cleaner in when i filled up? not sure if that had anything to do with it,i bought it used from a friend but he only had it in his car for a week so i dunno maybe it is fixin to go out....thanx for the post guys!!
