fuel pump check connecter?
chanley talon
773
14
Nov 10, 2005
Spencer, Indiana
Can someone take a photo of a fuel pump check connecter. Also how many positive cables and negative battery cables is there? Thanks alot. I know it under the hood but i dont know where.
make sure you get the right jumper connection. there is another one about 6" down the harness that is for a tach signal. if you put 12v to that you'll fry your battery.
mine didnt have the plug but i found the wire. With the key in the off position i can get the relay to fire with it in the on position i cannot . Is this normal? any way my pump is good but i cannot manual get it to fire? i here the relay but no action?
