Fuel pump and injectors?
talon1616
211
Mar 7, 2010
Erlanger, Kentucky
I have a 95 talon tsi awd. everyone says i should get bigger injectors and fuel pump. What do you think i should get. i think it already had 255 fuel pump. Just let me no what i should get. thanks. Oh and the turbo is a small 16g
Well find out if it has a 255 first of all and if it does get an afpr to prevent overrunning the stock one. If you upgrade the injectors just remember to that you need to be able to tune the car to do that. As far as what size; well it all depends on your goals, both short-term and long-term. Do you plan on maxing out the 16g? Do you think there is a possibility you will upgrade the turbo again later? Do you have a certain power goal? Do you want to run e85? Do you have other basic mods already? There are far too many questions that need answered before someone can really recommend a specific fuel set-up.
Fill out your profile with your mods, that will help determine.
Injectors depends on what you are tuning with and what fuel you will be using.
dude your questions are all over the place... Once you actually get the car you need to do all the maintenance on it first before you start worrying about mods. The fact the car you're looking at is modded already is an even bigger reason why you should make sure all the standard maintenance is done.
It would suck for you to spend a ton of $ on mods and then have the t-belt snap and take out your motor because you failed to do preventative maintenance.
Click the "Tech" tab at the top left of this site, then click on "Upgrade Paths".
And yes, like the previous members have said- DO YOUR MAINTENANCE FIRST.
As EclipseTical noted, please solve your general maintenance issues before you start modifying the car further.
Too many good DSM's have died because their owners stupidly increased the boost without proper supporting modifications or even basic vehicle maintenance.
Do things the right way first.
Yeah. If you just got the car, do ALL the maintenance on it.
Then worry about making more HP.
And we gotta know what your planning on doing. Boost/Mods wise.
I would definitly look over whatever mods have been done to the car as well as maintenance. You never know what kind of cheezy crap someone may have done to get more power.
Like putting a T in the pvc line going back to the intake Yes after the MAS. hhmm extra unmeasured air, burns fast and hot, car acted really mean. Saw that.
