Fuel pump and injectors question..??
UVaJester
219
Jun 14, 2003
Virginia Beach, Virginia
I am in the process if recieving all the parts I ordered for my 50 trim install... The few parts that I have got in, is all of the fuel system, which is a 255hp and 750cc injectors... My question is... Can I install the fuel pump, injectors and still run the stock turbo for a few days while i'm waiting for my other parts to come in the mail..?? I have dsmlink to tune... This may be a stupid question.. Thanks in advance...
Jester
While do-able, I wouldn't tune 750's with an AFC. You'd have to hack the MAS, and still pull out a lot of air readings.
I wouldn't do it, anyways.
You may need an AFPR with that 255. I got a 255 and had a terrible time keepng a good tune because sometimes the fuel pressure would be normal and other times it would jump really high and I would run really rich. An aeromotive solved that problem quick :thumb:
Spellmen said:
You may need an AFPR with that 255...
The AFPR and fuel rail will be the next add-on... as soon as I save some more $... Thanks again for everyone's advice..
Jester
