Fuel problems..please help
LowNismo17
Nov 1, 2003
Mobile, Alabama
sup everyone i am interested in buying this 97 GS-T with a 6-bolt swap with a walbro pump, stock injectors, no FPR, old style S-AFC, Big16G, A'PEXi FMIC, and full A'PEXi exhaust... that is pretty much the set up that matters about this question.. anyways the car smells like it is running really rich, but he has the S-AFC set really leaned out of the hi-throttle side... what could be wrong? it doesn't really run to its potential... this is kinda a hard question because i don't know exactly what everything is set on and etc.. but any info would help, i don't want to buy it and then have alot of problems out of it.. thanks alot for all the help..
it needs a regulator/bigger injectors/tunned is probably your answer
Is this car running a 1g cam sensor? if so did he do the Potentinometer fix to get rid of the random missfire, i have heard this can cause the car to run rich also.
i plan on putting 550 injectors, and aeromotive FPR on it once i get it but i am just trying to make sure nothing really is wrong with it..thanks for the info
