fuel pressure switch
If you are trying to change the fuel filter, and you dont want fuel every where.. Just pull the fuel pump fuse/relay. Then try to start the car. If it starts it will die, then try to start it again.. then you should be good. There shouldn't be any fuel pressure.. As far a the fuel shut off I dont think there is one!:dsm::dsm:
I'm not sure if N/T's have the same pump setup as GST's, but it's worth a shot. Try following the first few steps of this how-to. It will have you remove the back seat, remove the fuel pump cover, and unplug the fuel pump. Then start the car, let it die, and crank it over for a few seconds, as mentioned before.
2G FWD fuel pump install
They do have that cover. So you can just unplug it from the fuel pump.:dsm::dsm:
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
