Oil pressure switch
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
My oil pressure deity has been wrapped in black tape and while doing my turbo install it got bumped and fell off.... I need a new oil pressure switch(dummy light) and possibly a new oil pressure gauge unit. Names from looking at http://www.dsmtuners.com/forums/art...7-2g-engine-bay-electrical-connections-2.html
Anyone able to post part number for both or where I can get? The dummy light sensor is just complete stripPed which is why the black tape was holding the wires around the metal part thy screw to the oil filter unit.
It might also fix my oil gauge in the dash too so it willstop vein lazy and work when it feels like it :)
Thank you 19Eclipse90, also do you know what the wiring part numbers are because the dummy light one is destroyed its just bare wire wrapped around the end of the screw atm.
and the wiring on the pressure gauge unit is brail and cracking.
The small harness for the gauge unit is MD137539.
EDIT: That harness is no longer available! JNZ Tuning stated there have been zero in the states since June 2015.
The switch has no intermediate connections near the sensor itself. It runs inside the cabin before merging into a connector with other wires. I'd suggest cutting back the wire loom and solder/heat shrink new wiring there.
  • Wanted 6 bolt NT water pipe
    • chrisman287
