Fuel lines for 90 gsx
90gsx4g63
Mar 10, 2008
Pittsburgh, Pennsylvania
I've been searching for fuel lines or fuel line repair kits for 1st gen gsx. I did find a feed line kit at slowboyracing.com but I need all three lines replaced. I just wanted to know if anyone has had to replace their fuel lines, and if so, where did they find them.
Ok. I've never made fuel line before, but have made and flared a ton of brake line;should be similar. I removed the fuel pump access panel and the one fitting is so rusted that I'm afraid to touch it. If I try and loosen that fitting and it breaks or strips, am I looking at having to replace the pump also?
making fuel lines is just like brake lines. as far as the pump goes DO NOT BREAK OFF THE LINES FROM THE TOP OF THE SENING UNIT!!! they are a royal pain to fix!
