Fuel Level Gauge Sending Wire
T Money
244
Dec 3, 2004
Lancaster, Pennsylvania
I need to know what wire to tap into for the sending wire to hook up a fuel level gauge. Either back at the tank or somewhere up front. This is on a 95 AWD. I cant find it anywhere. Any help would be great!
2G AWD cars have dual sending units - one on each side of the tank. I don't even know where you'd tap into for the electrical connection....
Also keep in mind that fuel tank sending units operate off of resistance to determine your fuel level. Therefore, you need to match the resistance range on your gauge to your sending unit.
I think i will be able to get the ohm range close enough. Anything is better than the nothing that i have...
I think i found the spot to tap into on the back of the cluster - If i tap into the fuel gauge place, that should give me a reading, rite?
