fuel leak
95twinturboawd
240
Feb 26, 2009
jackson, Michigan
im getting a fuel pool tewn cyl 3-4 on the intake man, so i put new O -rings on those inj. and new gasketsin the man, but still getting the pool. but i did see that the fuel return line also look wet on the rail were the retune line meets. anything else i should look 4 thats
the fuel could be from the o ring on the fuel rail the return end it could be dripping down and running across the rail as you know moisture will stick to anything until the fuel drop is heavy enough to release good luck
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
