fuel injectors bad?
15poundsoffun
41
Aug 2, 2004
reno, California
this should be pretty much cut and dry are all the injectors supposed to pluse.. meaning when you touch the injector clips
i have pte 800 injectors and was just wondering ... thanks chris
Yeah, that is normal. Just incase you don't know how injectors work I will give you a quick run down. They use a magnite to open and shut the pin inside the injector. The pulsing you are felling is just the pin opening and shutting each time it injects fuel. So you are good to go. Hope that helps.
thanks thats what i thought we really much know but wasnt sure i was running lean and found the problem out after about 600 bucks worth of coils and such i am running 880 by pte and not really checked them but now i know and like g i joe said and knowing is half the battle LOL thanks for the info guys keep it up
