jking29
- 656
- 8
- Jun 7, 2005
Huntsville,
Ohio
I bought these on ebay and they were supposed to only have a 1000 miles on them. When they showed up, 2 of them were missing the top ring above the o-ring that goes up into the fuel rail. (circled in the pic) What I need to know is if these can be relaced. I was told by someone else that they had to be pressed on and should not be removable. I definitely know I can't run them as-is, because that ring is what keeps the o-ring from popping off up into the fuel rail and causing a massive fuel leak. By the way, they are Fuel Injector Clinic 550's. Should I just send them back and try and get a refund? Anyone that can give me some more info about them and what I should do would be GREATLY appreciated. Thanks
