**fuel Question Please Help **
1990gsx1781
190
Jun 28, 2008
Lynn, Massachusetts
ok ive look threw the forums havent seen anything so here we go. so far i have a stock rebuild motor. i have a 16g, mbc, 1g maf hacks, no emissions.... i just ordered a walbro 225lph, 550cc injectors, fuel filter to fuel real bigger feed line, bc 272/272 with obx cams, afpr, and i have a safc. my question is does this seem like a good setup any input on what im miss prob. alot haha. but my question is how do you set up the afpr like how do i adjust it when i put it on thanks guys
and has stock wires on it. any ideas
You'll need a fuel pressure gage of some sort. It's a rising rate FPR, right? You'll need to know what DSM's run stock for fuel pressure, start the car, pull the vacuum line off the FPR, and set it to stock (or what ever you tune for, but I doubt your going that route just now). Then re-connect the vacuum and go.
T don't know much about the fpr, but ive got mycar set up somewhat like yours and my thing is that I think you should get 650 injectors or bigger. cause once you get everything on and the boost turned up your car might go into fuel cut. my buddies got 550s and a 16g and he cant get on it without it shuting of the fuel due to lack of.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
