2G Fuel injector identification help
Brandon1972
Feb 11, 2023
Louisa, Virginia
Working on a 1999 Mitsubishi eclipse GST. I picked this car up it had been sitting for 15 years. I pulled the injectors to get them cleaned and realized one doesn’t match the others. At this point instead of getting them cleaned since they don’t match I’d like to get another set of Injectors. I think they are stock but just want to confirm that before getting more stock injectors. The black injectors are stamped 105F and each has its own number as listed: 38887, 38861 & 38930. The silver one is stamped INP-018. Can anyone tell me if these are indeed stock for a turbo 4g63 eclipse. Also any links yall could provide to a decent set of stock lifters that you trust.
Thanks, Brandon
Yes that is correct the silver one reads IND-018 and MDL450.
Ok was hoping they were all stock style because I have no idea if cars been tuned. And if it was I have no idea what size injector it was tuned to use. Looks like someone was chasing a problem and switched one out maybe.
Car is running and makes 15lbs of boost at 4000 rpms but want to pop hard after 4000 rpms. What tuning software is the best to use on these cars? I just need to start looking at some data from the car
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
