Fuel Injector Help
RyanR79
148
Nov 25, 2010
Denver, Colorado
Ok i have 1996 TSI with 40 over wiseco pistons,eagle rods,XS Power exhaust manifold, Tial Waste gate, TD05 20G, SAFC, FMIC, Full 3inch Exhaust.
DSM link Full version is going to be here on Monday im only running about 10 psi because if i raise it i will get fuel cut so im going to purchase a wally 255 and some bigger injectors so im curious on what size and what brand i should get and i want to no what you guys think?
Right now im running 14's in Colorado which is pretty good but my goal is to run low 13's here in this high altitude.
Thanks-Ryan
One thing i leaned and is not the worst advice, going a little larger of a injector is not a bad thing. If your going to be running DSMLink , its easy to compensate and it will keep your duty cycle low.
You do know you can run 12psi on a stock system right..Get your wally 255 and an afpr..I would buy 1000's or better and go with e85..I know you have e85 in colorado..
I could be wrong but I think it about 1 psi up for every 1000 feet in elevation you are..When I was at 7300 feet I could run 16 no problem..Then I came home and bam fuel cut, on same turbo..I did hit cut once before at 7300 but that was on creep..
Im running pump gas horse power goals i dont really no what im at now i believe im around 200-275 range so maybe like 300-350. So TalonRyder if im thinking 750 maybe i should go 850?
A fuel pressure regulator with gauge is nice to have. I installed a 255lph pump and using my DSMLink and wideband, i was noticing some rich fuel issues due to it. Id suggest a Aeromotive due to many, many, people use them but there are others that are good too. The FPR will help from irregular fuel maps and such. Bud92gsx is right about that.
You do know you can run 15psi on a stock system right..Get your wally 255 and an afpr..I would buy 1000's or better and go with e85..I know you have e85 in colorado..
15 psi on a stock fuel system from a 20g turbo...i dont see that as bein possible. 15 psi on a 14b turbo, yes quite possible
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
