Fuel Feed line????
When your in frony of the car it should be on your left (passanger side). I have a front wheel drive 2g but it should be the same. If its not then find your fuel filter on the fire wall and trace the line.
so mounting my fuel line to the nitrous on the side where the picture is, is wrong????
the side pictured is the return line. The feed line is on the opposite side (passenger side).
I wouldnt imagine youd want to tap your n2o into the return line. Id assume youd want it into the feed line....
The picture in the link show the fuel return.
You could run a fuel line for your nitrous from the feed or return, but it is recommended to do it at the feed, before the fuel rail.
It's not nessacerily wrong, but you should tap into the fuel line on the left side of the rail to be sure you are supplying the mixture with the correct amount of fuel.
Hey, I just replaced my fuel filter and it is on the pasender side of the car, right next to that big canister that is part of your EGR system...if you havent removed it yet.
sweet thanks, i mounted it on the wrong side of the car... good thing i didnt spray, ill re mount it, thanks for the help
