SBR 1g SS Fuel Feed Line
DSM1gTalon
36
Dec 8, 2004
Philadelphia, Pennsylvania
I was thinking about what your thoughts were on this kit. I know someone is gonna be a smart ass and tell me to search so I just wanna say I tried that, no luck. Anyway, since I have a leak on my feed line at the fitting on my sending unit and that rubber hose, I was thinking if whether or not I should just repace the whole line or not.
Opinions please...
On the SS subject, I have had good experience with using AN-06 SS line... I just followed this guide and sourced the hardware myself:
http://www.stevetek.com/R-FuelSys.html
I did things a bit differently as I used AN-06 adapters for the fuel rail, and I was also able to get a metric 14mm x1.25 (if I remember that right) adapter to adapt to the fuel pump assembly's hard line fitting... I think that I got that from Summit Racing. Lastly, I also used an Earl's fuel filter vs the K&N (it offers a replacable sintered bronze element that filters down to 30 microns).
I just installed the "kit" myself last weekend. It's really just a box of parts, so it would be easy enough to source the parts and get the machined rail adapter from SBR. My only complaint is the 90 degree fitting off the rail didn't fit with the throttle body stay. I cut the bottom part out and replaced the 90 with a straight fitting, but you could just as easily remove the stay.
I'd also suggest picking up a AN6 adapter for a fuel gauge since you lose the banjo fitting, where my gauge is now.
