ss fuel line
rayrayx11
165
Aug 8, 2008
riverside, Rhode Island
so i have most of the original fuel line off already. had to cut it a few different times. but im stuck now. where the line goes between the body and the sub frame i cant figure out an easy way of taking this off. any help would be much appreciated
Your talking about the stock fuel lines correct?
Best way is to unbolt the subframe, only way i could figure it... i tries pulling the sh*t out of them but no budge...
Might be able to hack them up into pieces if you have the right tools
Yeah, the easy way is to hack it down, then grab it with a big pair of channelock pliers and play tug-o-war until you win. Oh, and make sure you unbolted the last bracket that holds the line to the body, there's one buried almost out of sight. Use a flashlight and look down from above.
I left mine cut about 6inches just like you described... Left it alone and didnt bother me since you didnt see it much
I finally pulled out the rest of the line when i dropped the subframe to paint the bay
Cant remember but isnt there a bolt threaded real close the the subframe? I think its one of those "hard to get to" bolts which is why i left it alone..
yea i already unbolted the last bracket, chopped it down. i think its just going to be one of those out of site out of mind kind of things. not worth the trouble. as far as the new line did you put it through the same area ?
