fuel cut /or losing fire
freeman 188
211
Mar 6, 2007
medicine hat, AB, Canada
I have a 91 laser ,with greedy 18g turbo ,255 fuel pump ,450 injectors ,and so on .my problem is when it goes to 5k to 55k it suddenly shuts down until I let off gas running 14psi boost . didn,t have this problem with the 60 trim just slow spool ,any help would be appreciated :cry:
my car use to be auto but I changed it over to manual , about a year ago ,do I HAVE TO CHANGE THE ECU also or would it be worth the trouble
THE ECU I HAVE ,but the head went onto a 2.0l non-turbo and now it is sold , I guess I should have kept it ,that is what happens when you try to help someone out ,you always need part,s when there gone ,LOL what would be the advantage of going to a 2.3 stroker ,
