Fuel back spray from the filler neck
dalesmitsu
762
5
Jul 23, 2006
Alliance, Ohio
Like the subject says, I own an 1998 rs and fuel is spraying out filler neck when I try to fill it up at the pump.
I've started a thread on another forum, to give you more information to help me diagnose the problem.
Team 2GNT Forum - Viewing message
Also, have one in the newbie section here as well, but I asked about which is the correct vapor canister for the 420a.
http://www.dsmtuners.com/forums/newbie-forum/364135-correct-part-my-1998-rs.html
I searched found only evap emission problem threads for the turbo only, but I notice in my chiltons the fuel tank assembly is indentical to the fwd turbo.
Thanks ahead of time.
I have an AWD so the route is different but the filler necks have a secondary vent line to aid while filling the car, if that vent line is plugged or clogged it could be the source of your problem. basically the funnel effect. Just a possibility.
    • Sdcryan1
