420A Fuel Adjustment after head build
Gideon Talon
Banned Member
18
Apr 19, 2009
asheborough, Massachusetts
so. i just got my 1997 eagle talon 420a head port and polished put camshafts and adjustable cam gears in as well. Right after acceleration. It will sputter a little bit. i asked the mechanics and they said that i either need to get my ecu chipped or i need to buy this thing that adjusts my fuel. i forgot exact what the fuel adjusting object is called. i apologize if someone has already posted a question similar to this. Would just like to know from the dsm crowd here what they think.
its an apexi safc. If you are going to use one you need some kind of logger or at least a wideband so you can see what is going on when you make adjustments otherwise you are just shooting in the dark.
what ive been told i need is an fuel pressure regulator. Now another question. can i use a universal one, or does it have to be specifically for the 420a motor?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
